Hello ravi,
For example consider load is varying from 1N to 10N on a cantilever plate post-9665-0-74148600-1399971953_thumb.jp.
In that case you have to create two forces of 1N and 10N at the end of the load region.
Go to> Analysis> Force>
Under Global coordinate system change the load type from "Constant vector" to "Linear interpolation" as shown in the figure 1.bmp
Regards
Raviteja
ashok dasari likes this
Helllo ravi,
I am using hm12 may be you are using some lower version.
If u didn't get the distributed load, just increase the search radius more or less equal to the distance between the loads that you want to create the distributed load.
Raviteja
