Sign in to follow this
vmrao9
Modal Analysis using Optistruct
 *** ERROR # 151 ***
    This may be caused by insufficient disk space or some other
    system resource related limitations.
    (e.g. The Operating System or NFS cannot handle file size > 2 GB.)
 This error was detected in subroutine splncz4.
TIME SPENT IN MODULE :  SOLVER;   CPU=    243.74;   WALL=    900.54
TIME SPENT IN MODULE :   FINAL;   CPU=      0.08;   WALL=      0.27
 Detailed disk usage:
High usage overall   :11520.6 MiB,
Solver scratch       :10129.0 MiB,
Internal database    :  967.0 MiB,
Out-of-core assembly :    0.0 MiB,
Temporary files      :  424.6 MiB.
SOLUTION COMPLETED, THE FOLLOWING IS CPU/WALL CLOCK SUMMARY (IN SECONDS):
TOTAL TIME SPENT IN MODULE :READ    ;   CPU=      7.07;   WALL=      7.12
TOTAL TIME SPENT IN MODULE :PREPR1  ;   CPU=      0.06;   WALL=      0.09
TOTAL TIME SPENT IN MODULE :DESIGN  ;   CPU=      0.05;   WALL=      0.03
   Total time spent in section :PRPSL4  ;   CPU=     19.45;   WALL=     19.79
TOTAL TIME SPENT IN MODULE :PREPRO  ;   CPU=     33.77;   WALL=     36.10
TOTAL TIME SPENT IN MODULE :CHECKEL ;   CPU=      1.33;   WALL=      1.59
   Total time spent in section :PRASMB  ;   CPU=      0.16;   WALL=      0.16
   Total time spent in section :SPASMB  ;   CPU=     12.64;   WALL=     22.72
   Total time spent in section :EIGINPUT;   CPU=     13.88;   WALL=     76.06
TOTAL TIME SPENT IN MODULE :SOLVER  ;   CPU=    243.74;   WALL=    900.54
TOTAL TIME SPENT IN MODULE :FINAL   ;   CPU=      0.08;   WALL=      0.27
CUMULATIVE RUN TIME:     CPU=      286.09;     WALL=      945.75
Traceback exit report:
  RAM:            1433 MB total,   1076 MB available.
  Data arrays:     227 total,       149 allocated.
  DATA SET size      0 MB, ram_disk      0 MB
DATASET USAGE: ndirs: 1, nfiles 6, nsets: 7, nblocks: 7, mode: 8
 DIR: 0, size 924.2[MB], path "./" num_files 6
Please help...
Regards
Malli
Hi Malli,
Are you using 32 bit machine for the analysis?
if yes, I would suggest you to run the job on 64 bit machine as 32 bit machines cannot allocate memory more than 2GB
also, please check that the current job requires atleast 1.5GB RAM where as the available RAM is 1GB. So, increase the memory to run the job.
Hai,
Thank You for the reply.
The machine was 64 bit.
We changed the scratch directory path to another drive where 30GB space was available, After this change the job was completed successfully.
Regards
Malli
