Sign in to follow this
nsudhindhar
aspect ratio
Plz see Hypermesh help
This is the ratio of the longest edge of an element to either its shortest edge or
the shortest distance from a corner node to the opposing edge ("minimal
normalized height"). HyperMesh uses the same method used for length (min)
described below.
For 3-D elements, each face of the element is treated as a 2-D element and its
aspect ratio determined. The largest aspect ratio among these faces is returned
as the 3-D element’s aspect ratio.
Aspect ratios should rarely exceed 5:1
