Sign in to follow this
Smadiche
compliance is negative or large
Hi all,
I had given run in optistruct for linear static analysis
but it shows like this -
*** WARNING # 312
In static load case 10
the compliance is negative or large 1.389270E+08
Optimization/buckling analysis cannot be performed
due to possible rigid body mode
wat is this mean????
wat is compliance???
Can anyone pls help me??/:-({|=
Thanks&Regards
Sai
i had the same problem: i had a geometry and the loads where attached to a RBE2 Element. There was a failure in the DOF. I chanced that and the error disappeared. maybe that helps…… but i am not sure if this really caused the problem. good luck! ;-)
Check your boundary conditions. Large compliance means, your model "flys away".
One cause can be no stiffness, another as stated missing contact definitions, another can be missing links in rigids or wrong BCs.
Best regards,
Merula
