Sign in to follow this
sful
Plotting max stress curve of a component
Hello all,
In my analysis an imposed displacement is applied to a part (kind of compression load on helical spring). I want to plot a curve that will show me the maximum stress over the time/displacement. Problem is the max stress occurs at different position over the time/displacement, so how do i plot that in Hypergraph. Could someone help me please.
Tqvm
You can use the MeasureGroup "Dynamic MinMax Result" for this. Just contour your desired results type, activate the MeasureGroup, select "max" and create a new curve ("Create curves ..." in the Measure Panel). You might have to animate your results in order to "see" the curve.
Regards
