Sign in to follow this
get component name from a line or surface
hi, there!
how can I get the component name of a line or surface using tcl? is there a hm function that I could use.
example. If I select a surface with its number, how I could get its component name or ID
thanks!
Try this:
*createmark surfaces 1 999
(where "999" is the id of the surface)
to get the component id use then:
hm_getentityvalue surfaces 1 "collector.id" 0
to get the component name use then:
hm_getentityvalue surfaces 1 "collector.name" 1
Stefan
Stefan Hettel
Manager HyperWorks Support
Altair Engineering GmbH
Calwer Strasse 7
D-71034 Boeblingen, Germany
Tel.: +49 (0)7031 6208-46
Fax : +49 (0)7031 6208-99
mailto:hettel@altair.de
Hi tinh,
I tried the following code:
    *createmarkpanel line 1 "Please select the Line on the SAME component";
    set line1 [hm_getmark line 1]
    set compId [hm_getentityvalue lines 1 "by comp id" 0]
    hm_usermessage $compId
When I run this, it gives 1 as the output which is not the component id. Can you please tell where I am going wrong
 Sorry, the code is :
    set compId [hm_getentityvalue lines 1 "collector.id" 0]
It should be:
    set compId [hm_getentityvalue lines $line1 "collector.id" 0]
Pandurang likes this
