Sign in to follow this
Tejasd57
How to open hypermesh V11 file in V10?
You can export the hypermesh (V11) model in any solver format and then can import the same in hypermesh V10.
For Export
File-Export- Solver deck model
For import
File-import-solver deck model
For Export
For import
great
You can export out the .fem, then open it and edit the lines where it defines the solver/version and replace them with the lines from a "good" v10 .fem file. It should then be import-able back into v10. This works for v12 .fem to solve in v11 solvers so I 'm assuming you can do the same for your issue.
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
