Sign in to follow this
Takky.traverso
I cannot use "same as" assignment
Hello,all
I have made a symmetry bumper model on HyperMesh, so I want to make its property and material same as each other.
However, once I assigned as so, its not applied.
I use HyperMesh -RADIOSS Block12 format now.
could you give me an advice? :)
Hi Takky.traverso
Close all your HyperWorks application on your machine and follow the below:
Please delete setting files on your machine. Follow the link below on how to delete setting files:
http://forum.altairh...iles/?hl=delete
Also, delete .Altair folder in temporary directory. Go to Run and type in %Temp% and click OK (see the picture below)
Now open HyperMesh and try again.
Thank you very much,
I did as you taught me, but  nothing was changed.:(
Component > update > select comp > click triangle left of [card] button > select "same as" > click [same as] button > select other comp > return
when i check assignment after did them, it is returned as before change.
can you card edit the updated component and check the property and material ID for the same?
it should have the same property and material ID of the master component. Also make sure you have assigned PART as card image to master component.
