Sign in to follow this
edgar_quinto
TK GUI TUTORIAL
Hello, I am going thorugh the tutorial for the HW GUI TOOLKIT and I got stock when running it.
The example is as follows:
hwt::CreateWindow mytoplevel \
-windowtitle "Dialog Title"\
-noGeometrySaving \
-cancelButton Cancel \
-acceptButton OK \
-acceptFunc applyFXN \
-defaultButton Accept \
-minsize 470 300 \
-post;
proc applyFXN {args } {
tk_messageBox -message "The Createwindow function passes the \
toplevel window to the procedure listed so you must have args \
in the procedure. Args is $args";
destroy $args;
set recess [hwt::WindowRecess mytoplevel];
set section1 [label $recess.section1 \
-text "Section one label "\
-justify left \
-anchor nw \
-font [hwt::AppFont]];
pack $section1 -side top -anchor nw;
hwt::AddPadding $recess -side top -height [hwt::DluHeight 4];
set frame1 [frame $recess.frame1];
pack $frame1 -side top -anchor nw;
hwt::AddPadding $frame1 -side left -width [hwt::DluWidth 4];
set fileSelection [ hwt::AddEntry $frame1.entry1 \
-label "File Name" \
-labelWidth 15\
-entryWidth 42\
-listProc whenPressed "dialogBrowse $recess" \
-iconName msfolder \
-iconLoc -1 2 \
-withoutPacking \
-textvariable filename \
-state "normal" ];
proc dialogBrowse {args} {
variable filename
variable recess
set filename [tk_getOpenFile -parent $recess]
pack $fileSelection -side left -anchor nw;hwt::AddPadding $frame1 -side left -width [hwt::DluWidth 4];
set bWidth [hwt::DluWidth 50 [hwt::AppFont]];
set bHeight [hwt::DluHeight 14 [hwt::AppFont]];
set button1 [hwt::CanvasButton $frame1.button $bWidth $bHeight \
-command "[namespace current]::importFile" $recess \
-text import \
-state normal \
-takefocus 1\
proc importFile {args} {
tk_messageBox -title "GUI Checklist" \
-message "The file has been imported." \
-icon info \
-parent $args \
-type ok;
pack $button1 -side left -anchor nw;
It is a very simple code that displays a window with a input box to select a file.
I get an error message when running it that says there is no such variable as recess.
Does anybody know where to look for the syntax of the getOpenFile command?
Thanks!
I tested and see it run normally!
Anyway you can try again with variable "::recess" instead of "recess". This will link recess to global scope and you need not declare by "variable recess"
tk_getOpenFile is a tk command, you look for help in Tcl/Tk manual
regards,
tinh
Thanks!
You are right, it works fine in the script editor, but in the tutorial page it does not.
Once I have completed the script it is not showing the radio buttons.
Do you know what is missing?
-noGeometrySaving \
-acceptButton OK \
-minsize 470 350 \
-post;
destroy $args;
-justify left \
-anchor nw \
-labelWidth 15\
-entryWidth 42\
-iconLoc -1 2 \
-withoutPacking \
-state "normal" ];
variable recess
variable filename
set filename [tk_getOpenFile -parent $recess ]
-text import \
-state normal \
-takefocus 1\
-icon info \
-parent $args \
-type ok;
hwt::AddPadding $recess -side top -height [hwt::DluHeight 7];
set section2 [label $recess.section2 \
-text "Section two label" \
-justify left \
-anchor nw \
pack $section2 -side top -anchor nw;
set frame2 [frame $recess.frame2];
pack $frame2 -side top -anchor nw;
hwt::AddPadding $frame2 -side left -width [hwt::DluWidth 4];
set labelWidth 17
set entryWidth 15
set entry1 [hwt::AddEntry $frame2.entry1 \
-label "Entry field label " \
-labelWidth $labelWidth \
-entryWidth $entryWidth \
-textvariable [namespace current]::entry1TextVariable \
-validate real \
-state normal \
-withoutPacking];
pack $entry1 -side top -anchor nw;
hwt::AddPadding $frame2 -side top -hegiht [hwt::DluHeight 4];
variable dropDownList; set dropDownList [list Red Blue Green Yellow ];
set entry2 [hwt::AddEntry $frame2.entry2 \
-label "Combo box label:" -labelWidth $labelWidth \
-text "Red"\
-entryWidth [expr {$entryWidth -2}]\
-listVar fromPopDown noTyping dropDownList \
-state normal ];
pack $entry2 -side top -anchor nw;
hwt::AddPadding $recess -side top -hegiht [hwt::DluHeight 7];
set section3 [label $recess.section3 \
-text "Section three label." \
-justify left \
-anchor nw \
pack $section3 -side top -anchor nw;
hwt::AddPadding $recess -side top -hegiht [hwt::DluHeight 4];
set frame3 [frame $recess.frame3];
pack $frame3 -side top -anchor nw;
hwt::AddPadding $frame3 -side left -width [hwt::DluWidth 4];
set rbl [radiobutton $frame3.rb1 \
-text "Option one"\
-variable "[namespace current]::optionVariable" -value one ];
pack $rb1 -side top -anchor nw;
hwt::AddPadding $frame3 -side top -width [hwt::DluHeight 4];
set rb2 [radiobutton $frame3.rb2 \
-text "Option two"\
-variable "[namespace current]::optionVariable" -value two ];
pack $rb2 -side top -anchor nw;
set rb3 [radiobutton $frame3.rb3 \
-text "Option three"\
pack $rb3 -side top -anchor nw;
Best regards.- Edgar
