Sign in to follow this
jeunehomme
creat group of nodes
Which User Profile do you use ?
I justly check Nastran, LS-DYNA, Optistruct,... the panel "constraints" is there (see screenshots)
Hi Mark,
What do you mean by group of constraints?
You can create a node set and create constraints using the node set.
Is there any way to organize constraints in sets/groups?  For instance, I want to group by 3 different constraints I have on the same node and then make a second group that has 4 different constraints on that same node.
Hi Mark,
I don't see a way to create a set for constraints/loads.
If 3 different constraints are completely independent the you can create 3 different load collectors but these load collectors can't be grouped.
