Sign in to follow this
AK_74
How to create path plot curve?
In Hyperview i can build plots, but can`t find how to create plot through node path. It is not interesting Time argument in static analisys, but i cant extract even node coordinates value for X axis on the graph.
post-32818-0-85737600-1413380961_thumb.j
you can create this at the Hyperview client, not Hypergraph. The result is a curve in Hypergraph, e.g. countor value / distance (or contour value / ID, or contour value / position)
If you have a nodal contour plot (like at the left side of your picture), then create a "Measure" and select "Node Path". Click start node, then end node and create a curve.
It works also on section cuts !!!
Best regards,
Mario
