BeMa86
Weight
On 11/23/2015 at 1:56 PM, Rahul Ponginan said:
The total mass at each iteration of an optimization is output to the .out file
Hi! I cannot see the mass of my resulting (final iteration) design space. I see the mass of the volume fraction response, but I also don't see that this response changes through iterations. I made a constraint on volume fraction and put an upper bound to 0.5 of the initial volume. From what I read on one of your tutorials, this means that the solver is constrained to go under this value of volume fraction.
How can I measure the mass of the final iteration? And is it right that the volume fraction is not changing? I will attach my output file. Thank you for your help
hub_model_3.out
hub_model_3.res
