Sign in to follow this
Multiple curve graphing
Is there any function which allows me to plot two curves - one from an excel file, and the other from a simulation run onto the same graph for comparison/analysis?
Thanks in advance!
HyperGraph (or the graphing portion of HyperView) can do all of the curve overlay functions. From Excel, you will need to export the curve in CSV or TXT format, but your simulation results data can probably be read directly from the solver results file.
ETG is absolutely right. Use "Build Plots" panel in HyperGraph (HG).
The Build Plots panel constructs multiple curves and plots taht can be overlaid in a single window or each curve can be assigned to a new window.
Following plot data files are supported.
ADAMS REQ and matrix files
Abaqus mass from DAT files
DADS graph files
GENESIS history files
Altair HyperForm DAT files
Altair HyperMesh RES files
Altair MotionSolve files
Altair MotionView shock output files
Altair OptiStruct files
Log files
Mass, volume, and frequencies from out files
LS-DYNA general time history files
LS-DYNA time history files:
• ABSTAT
• BNDOUT
• DBFSI
• DEFGEO
• Mass from D3HSP
• ELOUT
• GCEOUT
• GLSTAT
• JNTFORC
• MATSUM
• NODFOR
• NODOUT
• RBDOUT
• RCFORC
• RWFORC
• SBTOUT
• SECFORC
• SLEOUT
• SMDYN6
• SPCFORC
• SPHOUT
• SWFORC
• TRHIS
MADYMO time history files
MADYMO TQ3
NASTRAN:
• Mass and frequencies from f06 file
• Complex results from SOL 108 and 111
‚àí Displacement
‚àí Velocity
‚àí Acceleration
‚àí PSD (displacement, velocity, acceleration)
‚àí SPC force
‚àí Element force (CELAS, CDAMP, CBUSH)
• HyperView results from OP2 files
PAMCRASH time history files
RADIOSS T01 time history files
WINGZ DIF files
Excel (.csv)
Multicolumn ASCII
XYDATA files
User-defined import templates and external readers to directly read any file format
Tab delimited files
In addition to the standard set of import templates, an open interface for creating custom import filters is provided. Using import language and external readers, you can write import templates for most any ASCII data file not directly supported in the program.
