tinh 739 Report post Posted November 25, 2014 Hi all.i made some hypermesh macros in form of "toolbar"if you feel it interesting, please send me your mcid flamenco7641, Iron_Man59, varthamanan and 3 others like this Quote Share this post Link to post Share on other sites
NSKRTLUS 5 Report post Posted November 25, 2014 Congratulations,it really looks so interesting Quote Share this post Link to post Share on other sites
Guest Report post Posted November 25, 2014 Interesting! But if you could share us how to do that, it's even more interesting Quote Share this post Link to post Share on other sites
tinh 739 Report post Posted November 26, 2014 Interesting! But if you could share us how to do that, it's even more interesting Hiii Mr.Quy to measure (diameter, surf-surf distance, ...) => click on corresponding toolbar buttons pick a circle => it shows diameter and radius pick 2 surfs => it shows distance pick a surf then a line => it shows distance, ... i add options to measure distance at closest position or picking position (ex. if in case 2 surfs or surf-line are not parallel) Quote Share this post Link to post Share on other sites
Guest Report post Posted November 26, 2014 No, I'm speaking about ... TCL script, not its usage Quote Share this post Link to post Share on other sites
tinh 739 Report post Posted November 26, 2014 it's a secret!i'll give a brief explain (actually difficult to explain fully in english, i am sorry)- diameter measure: i used only command hm_getbestcircle, it return diameter value directly just in one click- surf-surf measure: when click on surf, it creates a node at clicking position, the node then projected to alternative surf, projecting direction is not normal to the surf but make equally angle with each surf (so in case 2 surfs not parallel then => get correct distance)- surf-line measure: similar to surf-surf, but temp node will be created on line, it then projected normally to surf (to find normal distance) and hm_getdistancefromnearest on surf to get true distance- line-line measure: similar to surf-surf, but after temp node created on a line, a closest position from it on the alternative line will be get (hm_getdistancefromnearest)- segment-segment (used when measuring height of a bead): i do some vector operations to find common perpendicular line of the two segment, length of it is distance between 2 segments, with option "extended closest postion" then this value is reported, in case of "closest position" it is compared to relative position between 2 segments ( as edge-to-edge contact calculation) flamenco7641 likes this Quote Share this post Link to post Share on other sites
Guest Report post Posted November 26, 2014 Thank you!I'm looking for a sample code to create a customized toolbar like yours. I searched within HM's documents but I found nothing for this moment Quote Share this post Link to post Share on other sites
tinh 739 Report post Posted November 27, 2014 Hii Mr.Quybelow is code to make my toolbaractually create toolbar can be done as in "hmsettings.tcl" file. but i modify something to fix errors when starting hm or first invoking to the functions proc ::nvtb:_DestroyToolBar {ToolBarName} { if {[winfo exists ._ViviToolBar-$ToolBarName]} { destroy ._ViviToolBar-$ToolBarName } foreach window [winfo children .] { if {[string match *.minibartoplevel* $window]} { foreach window2 [winfo children $window] { if {[string match *ViviToolBar-$ToolBarName* $window2]} { destroy $window break } } } } } proc ::nvtb:_CreateMeasurementToolBar {} { ::HM_Framework:_CreateMinibar . ViviToolBar-Measurement HyperMesh:HyperMesh:_blank ::HM_Framework:_SetMinibarIconList ViviToolBar-Measurement [list \ [list [list p_CreateMinibarIcon [file join $::nvtb::v_ImageDir MeasureCircleDiameter-24.png ] "if {!\[namespace exists ::nvtb\]} {source \"$::nvtb::v_InfoScript\"; ::nvtb:_MeasureCircleDiameter } else {::nvtb:_MeasureCircleDiameter }" {Circle Diameter} 1] ] \ [list [list p_CreateMinibarIcon [file join $::nvtb::v_ImageDir MeasureDistanceSurfSurf-24.png ] "if {!\[namespace exists ::nvtb\]} {source \"$::nvtb::v_InfoScript\"; ::nvtb:_MeasureDistanceSurfSurf } else {::nvtb:_MeasureDistanceSurfSurf }" {Surf-Surf Distance} 1] ] \ [list [list p_CreateMinibarIcon [file join $::nvtb::v_ImageDir MeasureDistanceSurfLine-24.png ] "if {!\[namespace exists ::nvtb\]} {source \"$::nvtb::v_InfoScript\"; ::nvtb:_MeasureDistanceSurfLine } else {::nvtb:_MeasureDistanceSurfLine }" {Surf-Line Distance} 1] ] \ [list [list p_CreateMinibarIcon [file join $::nvtb::v_ImageDir MeasureDistanceLineLine-24.png ] "if {!\[namespace exists ::nvtb\]} {source \"$::nvtb::v_InfoScript\"; ::nvtb:_MeasureDistanceLineLine } else {::nvtb:_MeasureDistanceLineLine }" {Line-Line Distance} 1] ] \ [list [list p_CreateMinibarIcon [file join $::nvtb::v_ImageDir MeasureDistanceSegmSegm-24.png ] "if {!\[namespace exists ::nvtb\]} {source \"$::nvtb::v_InfoScript\"; ::nvtb:_MeasureDistanceSegmSegm } else {::nvtb:_MeasureDistanceSegmSegm }" {Segment-Segment Distance} 1] ] \ [list [list p_CreateMinibarIcon options-24.png "if {!\[namespace exists ::nvtb\]} {source \"$::nvtb::v_InfoScript\"; ::nvtb:_Options } else {::nvtb:_Options }" {Options} 1 ] ] \ ] ::HM_Framework:_AddMinibarToDockframe ViviToolBar-Measurement .mainFrame.dockframe_top set ::HM_Framework::Minibar::ViviToolBar-Measurement:_status 1 } proc ::nvtb:_CreatePullDownMenuForToolBar {ToolBarName} { #set menu [. cget -menu].view.toolbars set menu [hm_framework getpulldowns].view.toolbars if {[catch {$menu index ViviToolBar-${ToolBarName}}]} { $menu add checkbutton \ -indicatoron 1 \ -offvalue 0 \ -onvalue 1 \ -variable ::HM_Framework::Minibar::ViviToolBar-${ToolBarName}:_status \ -command "::HM_Framework:_ToggleMinibar ViviToolBar-${ToolBarName}" \ -label ViviToolBar-${ToolBarName} \ -underline 0 return 0 } else { return 1 } } Quote Share this post Link to post Share on other sites
NSKRTLUS 5 Report post Posted November 27, 2014 Hi tinh, Thank you so much for sharing it with us Quote Share this post Link to post Share on other sites
Guest Report post Posted November 27, 2014 Thank you so much Tinh! Quote Share this post Link to post Share on other sites
surenagu 0 Report post Posted December 18, 2014 Hi.. Would you please send me the code.. suresh.babuks@gmail.com Quote Share this post Link to post Share on other sites
surenagu 0 Report post Posted December 18, 2014 Thanks for sharing.. Is this the complete code?? Quote Share this post Link to post Share on other sites
tinh 739 Report post Posted December 23, 2014 Thanks for sharing.. Is this the complete code?? Hi, below is complete code, after some persons used, i fix some bugs now already 4 persons use it If you like, please send me your MCID, i just want to record number of users Quote Share this post Link to post Share on other sites
Karthi keyan 1 Report post Posted December 26, 2014 Hi tinh, What is the MCID? and when i try to run this script it is also saying "COULD NOT VERIFY MCID". What should i do? RegKarthi Quote Share this post Link to post Share on other sites
tinh 739 Report post Posted December 27, 2014 On 26/12/2014 at 5:26 PM, Karthi keyan said: Hi tinh, What is the MCID? and when i try to run this script it is also saying "COULD NOT VERIFY MCID". What should i do? Reg Karthi Really? Could you try again with this new updated: Quote Share this post Link to post Share on other sites
Karthi keyan 1 Report post Posted December 29, 2014 I tried with the updated one also.. It is also coming same Unexpected Error Could not verify your MCID. Please contact to tinh411@gmail.com Quote Share this post Link to post Share on other sites
tinh 739 Report post Posted January 7, 2015 Hi all this second toolbar has auto-detect mesh features and help fast create some element patterns with less picking Quote Share this post Link to post Share on other sites
tinh 739 Report post Posted January 16, 2015 Hi all i finished set of 3 toolbars. Hope new hypermesh version will have new nicelooking ones Quote Share this post Link to post Share on other sites
Guest Report post Posted March 2, 2015 It is throwing Error while executing this script in Hyperworks 12.0 Can you please help me on this .I am trying to call the tcl file which was provided in the zip file Regardssri Quote Share this post Link to post Share on other sites
tinh 739 Report post Posted March 5, 2015 It is throwing Error while executing this script in Hyperworks 12.0 Can you please help me on this .I am trying to call the tcl file which was provided in the zip file Regards sri Hi, could you please inform me what error occurred? input below command at command window to know detail set errorInfo Quote Share this post Link to post Share on other sites
varthamanan 0 Report post Posted July 19, 2015 can you please share the macro as tcl file Quote Share this post Link to post Share on other sites
varthamanan 0 Report post Posted July 20, 2015 #created#varthamananproc CreateToolBar { carName jataList } { #Create Toolbar ::HM_Framework:_CreateMinibar . $carName; #Add Icon foreach Data $jataList { set iconfile [ lindex $Data 2 ] set cmd [ lindex $Data 1 ] set name [ lindex $Data 0 ] ::HM_Framework:_AddIconToMinibar $carName \ [ list p_CreateMinibarIcon [ file tail $iconfile ] $cmd $name 1 ]; } #Pack Toolbar ::HM_Framework:_AddMinibarToDockframe $carName .dockframe_center; #Destroy}proc RedrawWindows { } { set pos [ hm_getcommandposition ] if { $pos == "top" } { hm_setcommandposition bottom hm_setcommandposition top } else { hm_setcommandposition top hm_setcommandposition bottom }}set jataList ""# quick edit panelset EditIcon "nodesInterpolateOnSurf-24.gif"set jataList "$jataList { {Quick Edit} { ::face {args} } $EditIcon }"# automesh panelset MeshIcon "meshLines-32.gif"set jataList "$jataList { {AutoMesh} { hm_pushpanel \"automesh\" } $MeshIcon }"# check panelset CheckIcon "check.gif"set jataList "$jataList { {Element Checks} { hm_pushpanel \"check elems\" } $CheckIcon }"## vis buttonset MeshIcon "distanceBetweenNodes-24.gif"set jataList "$jataList { {Distance} { hm_pushpanel \"distance\" } $MeshIcon }"## vis buttonset MeshIcon "edgesGeneral-24.gif"set jataList "$jataList { {Edges} { hm_pushpanel \"edges\" } $MeshIcon }"# vis buttonset MeshIcon "elem-normal.gif"set jataList "$jataList { {Normals} { hm_pushpanel \"normals\" } $MeshIcon }"# vis buttonset MeshIcon "intersectionGUI.gif"set jataList "$jataList { {intersection} { hm_pushpanel \"penetration\" } $MeshIcon }"# vis buttonset MeshIcon "numbers-24.gif"set jataList "$jataList { {Numbers} { hm_pushpanel \"numbers\" } $MeshIcon }"# vis buttonset MeshIcon "pan.gif"set jataList "$jataList { {Translate} { hm_pushpanel \"translate\" } $MeshIcon }"# vis buttonset MeshIcon "pointsExtractParametric-24.gif"set jataList "$jataList { {Project} { hm_pushpanel \"project\" } $MeshIcon }"# vis buttonset MeshIcon "blankNesting-24.gif"set jataList "$jataList { {Reflect} { hm_pushpanel \"reflect\" } $MeshIcon }"# vis buttonset MeshIcon "gap-24.gif"set jataList "$jataList { {Replace} { hm_pushpanel \"replace\" } $MeshIcon }"# vis buttonset MeshIcon "erase-16.gif"set jataList "$jataList { {Edit elements} { hm_pushpanel \"edit element\" } $MeshIcon }"# vis buttonset MeshIcon "objectives.gif"set jataList "$jataList { {Replace} { hm_pushpanel \"split\" } $MeshIcon }"## vis buttonset MeshIcon "linesExtractEdge-24.gif"set jataList "$jataList { {Smooth} { hm_pushpanel \"smooth\" } $MeshIcon }"## vis buttonset MeshIcon "linesOffsetConstant-24.gif"set jataList "$jataList { {node edit} { hm_pushpanel \"node edit\" } $MeshIcon }"## vis buttonset MeshIcon "post-shaded-16.gif"set jataList "$jataList { {node edit} { hm_pushpanel \"ruled\" } $MeshIcon }"## vis buttonset MeshIcon "3dElements-24.gif"set jataList "$jataList { {node edit} { hm_pushpanel \"drag\" } $MeshIcon }"## vis buttonset MeshIcon "solidDragLine-24.gif"set jataList "$jataList { {node edit} { hm_pushpanel \"solid map\" } $MeshIcon }"## vis buttonset MeshIcon "morphingVolume-16.gif"set jataList "$jataList { {node edit} { hm_pushpanel \"HyperMorph\" } $MeshIcon }"proc ::face {args} {*appendmark elements 1 "by adjacent"hm_saveusermark elems 1;*appendmark elements 1 "retrieve"hm_highlightmark elems 1 h;}# create toolbarcatch { ::HM_Framework:_DeleteMinibar CustomToolBar }CreateToolBar fanels $jataList# redraw windowRedrawWindows Quote Share this post Link to post Share on other sites
varthamanan 0 Report post Posted July 20, 2015 this is my toolbar created by most using command Quote Share this post Link to post Share on other sites
IsraGuerra 0 Report post Posted June 26, 2017 Hi tinh, could you please share this macro with me? It looks very interesting. Do you know if it works with hypermesh 2017? Thank you in advance Quote Share this post Link to post Share on other sites
