How to customize pull down menu?
Add the following codes (change to your needs) into "hmcustom.tcl" :
set mypath "C:/Users/MYNAME/myscripts";
set top_menu [hm_framework getpulldowns]
catch {$top_menu delete [.hmMainMenuBar index "MyMenu"]}
catch {destroy $top_menu.custom}
menu $top_menu.custom -tearoff 0
$top_menu insert 20 cascade -label "MyMenu" -menu $top_menu.custom
set cat1 $top_menu.custom
$cat1 add cascade -label "Category 1" -underline 0 -menu [menu $cat1.mnu1 -title "Cat-1"]
$cat1.mnu1 add command -label "Script 1" -command "source {$mypath/script1.tcl}" -underline 0
$cat1.mnu1 add command -label "Script 2" -command "source {$mypath/script2.tcl}" -underline 0
$top_menu.custom add separator
set cat2 $top_menu.custom
$cat2 add cascade -label "Category 2" -underline 0 -menu [menu $cat2.mnu2 -title "Cat-2"]
$cat2.mnu2 add command -label "Script 21" -command "source {$mypath/script21.tcl}" -underline 0
$cat2.mnu2 add command -label "Script 22" -command "source {$mypath/script22.tcl}" -underline 0
Start HM and you get your customized menus, see screenshot.
Iron_Man59 likes this
First of all, great job, this topic is really useful!
I just have one question. How do I create a second level of cascade? I want that after "Category 1" a new cascade appears with "Category 1_1" and "Category 1_2" and then I'll place my macros on those menus.
Lawrence
Lawrence
Hi
you can make sub-menu by pathname add cascade
http://www.tcl.tk/man/tcl8.5/TkCmd/menu.htm#M26
ngoc.tam likes this
I can not file location's hmcustom.tcl , Is this the same hmsettings.tcl and same location. When i add the codes, i can not see the new Menu also, But when i run the new codes. Its ok. But i can not use the sub-menu. and This sub-menu can use normally if i call direct
thanks a lot for the topic, it's very useful! It works great the first time I open HM.
However, I have a problem when I change the user profile (Preferences->User Profiles). If I change the profile, my menu disappears.
I understood that, changing the profile, all the menus are reloaded and the hmcustom.tcl is loaded only the first time, but I didn't found a workaround to reload my menu.
Thanks for any reply.
Regards
21 hours ago, Jack LC said:
Regards
B)
to reload hmcustom.tcl after userprofile changed, add below code to hmcustom.tcl:
set ::hmcustomtclpath [info script]
proc ::reloadhmcustomtcl args {
     source $::hmcustomtclpath
if {[lsearch -exact [hm_framework getregisteredprocs after_userprofile] ::reloadhmcustomtcl]!=-1} {
    hm_framework registerproc ::reloadhmcustomtcl after_userprofile
Pandurang and Jack LC like this
hello,
 i am new to this forum. please can you tell me how to use this option?
thank you ,
I have run this script the option (my menu) is opening in hm but the script is not taking from
set mypath "E:/vedio/scripts";
and when I press the category 1. -tria per node.tcl it shows error (no such file or directory) like already showed in image.
