How to compute normal vector of quad4?
In Hypermesh's database, I see :
normalx
      The x component of the element normal (double).
normaly
     The y component of the element normal (double).
normalz
     The z component of the element normal (double).
I'm curious to know how Hypermesh compute the normal vector of a quad4 element ?
In simple case, all 4 nodes of quad4 are coplanar, it's simple.
However, when the 4th node is not coplanar to 3 others, how to compute?
And for quad8 elems, how to do compute ?
Thanks,
It's all about the node id's how it was placed in element card
Check the elem card edit for the particular element.
If the node id's are placed in  anti clockwise then the normal is toward us (Red).
If the node id's are placed in clockwise then the normal is Opposite(Blue).
@Karthi : thank you for your reply. But that's not an answer to my question
Hi I think it is N1N3 x N2N4 so this can eliminate affect of warpage
it is similar to when we calculate dihedral angel of solid elems we have to take normal of each face as that
@tinh: I do a test with two quad4 elements (see my quad4.zip attached)
1st element : all 4 nodes are coplanar.
2nd element: the 4th node was moved out of plan
Run this simple script:
proc get_normal { eid } {
set nx [hm_getentityvalue elems $eid "normalx" 0]
set ny [hm_getentityvalue elems $eid "normaly" 0]
set nz [hm_getentityvalue elems $eid "normalz" 0]
puts [format "E= %d : normal=(%0.3f ; %0.3f ; %0.3f)" $eid $nx $ny $nz]
get_normal 1;
get_normal 2;
I got the same normal vector for two elements.
E= 1 : normal=(0.000 ; 0.000 ; 1.000)
E= 2 : normal=(0.000 ; 0.000 ; 1.000)
Try it and tell me what do you think about that.
quad4.zip
Hi Mr.Quy
I cannot open your file on hm12
but i test a warping quad and surprised that its normal is calculated by N1N2N3
:o
post-3195-0-52112300-1418833608_thumb.pn
can this confict with solver specific?. I read manual that y axis of element coordinate system where stress output, lies on plane defined by "G1,G2,G3 and G4", means it should be N1N3 x N2N4
Hy Tinh,
The requirement is to project a node on a user defined plane, whose normals keep changing for different files
i wanted to obtain the normal x, normal y, normal z for passing in the parameter for *createplane
*createmark nodes 1 7053
set nodeIds [ hm_getmark nodes 1 ]
if { ! [ Null nodeIds ] } {
set nodeId [ lindex $nodeIds 0 ]
set x [ hm_getentityvalue NODES $nodeId "x" 0 ]
set y [ hm_getentityvalue NODES $nodeId "y" 0 ]
set z [ hm_getentityvalue NODES $nodeId "z" 0 ]
*createmark nodes 1 7099
set xx [ hm_getentityvalue NODES $nodeId "x" 0 ]
set yy [ hm_getentityvalue NODES $nodeId "y" 0 ]
set zz [ hm_getentityvalue NODES $nodeId "z" 0 ]
set x_vector [ expr { $xx - $x } ]
set z_vector [ expr { $zz - $z } ]
*createmarkpanel nodes 1 "Select 3 nodes "
set NodeList1 [ hm_getmark nodes 1 ]
*clearmark nodes 1
set  CoordX [hm_getentityvalue NODE $NodeList1 "x" 0]
set  CoordY [hm_getentityvalue NODE $NodeList1 "y" 0]
set  CoordZ [hm_getentityvalue NODE $NodeList1 "z" 0]
*duplicatemark nodes 1 28
*createmark nodes 1  550003
*createplane 1 -0.596426819 -1.81399629e-008 0.239601619 $CoordX $CoordY $CoordZ
*createvector 1 $x_vector 0 $z_vector
*projectmarktoplane nodes 1 1 1 1
I tried the above code, and got an error:
    while executing
"*projectmarktoplane nodes 1 1 1 1 "
Please suggest me how to proceed ahead.
Thanks in advance.
Arjun Arasan
from HM13, you don't need to do such complex, use available functions
example
*createmarkpanel nodes 1 "Select nodes to project to plane:"
if {[hm_marklength nodes 1]} {
     set Plane [hm_getplanepanel "Specify a plane:"]
     if {[llength $Plane]==2} {
          set Vector [lindex [hm_getdirectionpanel "Specify a vector:"] 0]
          if {[llength $Vector]==3} {
               eval *createvector 1 $Vector
               eval *createplane 1 [join [join $Plane]]
Dear Tinh,
Thank you for the help.
could you please explain the logic behind them?
what does it do internally?
is it similar to our vector product of 2 vectors specified by 3 nodes co ordinates?
It would be of great learning, if explained.
Thanks and regards,
Arjun Arasan
11 hours ago, ArjunArasan said:
Dear Tinh,
Thanks and regards,
Arjun Arasan
example Vector is {1 0 0} then "eval *createvector 1 $Vector" will be "*createvector 1 1 0 0"
if Plane is {{1 0 0} {0 0 0}} then "[join [join $Plane]]" will be "{1 0 0 0 0 0}"
and "eval *createplane 1 [join [join $Plane]]" will be "*createplane 1 1 0 0 0 0 0"
it is not vector product. It is tcl syntax that you can refer on tcl manual
