Seth.Prashant
AcumeshSim problem
I apologize if I am not posting this in the correct forum but I am having a problem when I am meshing a geometry in Acuconsole using AcuMeshSim.
I am getting this warning message for my mesh settings.
acuMeshSim: <SIMM_WRN_MSG>:Circumsphere with <= 0 height
Although this is actually just a warning message but my mesh process always gives an error later and thus I think this might be related to the failure.
I would like to know what might be causing this and which setting should I change to get rid of this warning/error?
Thanks in advance.
It is tough to pin point the issue without examining the database.
Could you check if it is similar to the following?
http://forum.altairhyperworks.com/index.php?/topic/13917-issue-with-vwt/#entry20354
- either surface mesh has very small/skewed elements, that are leading to problem with mesh generation
- there is very small gap between wheels and the ground, or probably no gap?
