Sign in to follow this
Surface Plotting in Hypergraph 3D
Is it possible to plot a 3D surface using tabular data?  Currently, all I see is a method to use tabular x,y data and a z expression.
HyperGraph 3D by itself only allows expressions for surface plots, to plot from a file with tabular data, you will need a macro (TCL script)
If you are a commercial customer, you can contact your local support for a script that will help you do the same @ http://www.altairhyp...ortProduct.aspx
