soumitra2102
A problem in an interface Type21
When I run the hf file of my model created just as per the tutorial 'Simple draw forming', at the begining of the process the solver didn't prompt fo any error. But at the end of 7th animation file, the process terminated saying 'The run encountered a problem in an interface Type21: You may need to check if there is enough clearance between the tools'.
Please help me to solve the problem.
Hi Soumitra,
I am having the same error. Did you find any solution for this type of error?
Hi Shripal,
Can you please share the files so that we can check and suggest the possible workaround.
On 5/29/2017 at 7:46 AM, George P Johnson said:
Hi Shripal,
Hi George,
I sent you .hf file on dropbox. Please check it. I am looking forward to hear from you soon.
4 hours ago, santhosh bhandari said:
Hi Shripal,
Please find the attached *.RAD file with the result file.
Also, i have switched off the adaptivity and setup the model. Do look at the results and revert back.
santhu
independent_layers_with_resin_new.zip
Hi Santhosh,
Thank you for sharing this file. But i want to run the simulation using connecting material (resin) between the layers. In this shared file you deleted the resin components. Can you guide me how can i setup the simulation with resin betweeen the layers?
Shripal
