On 2/6/2018 at 5:53 AM, Saran said:
Hi sir,
I was also modeling the simplest model possible. just the axial load on a 2d rod. and I received the same error.
I switched profiles but it did not resolved the problem.
I have totally two elements, and the MHCPLL. nothing complicated.
here is the error
 *** ERROR # 2372 ***
 No PWELD properties exist in the bulk data.
 *** ERROR 14: Missing property #    1 referenced by   CWELD # 1.
Even i am getting the same error
Can any one help with the solving procedure ?
On 2/22/2017 at 10:25 AM, Sohrab said:
I finally did it!!
I was previously an ANSYS user. I should say despite being very powerful the steps in hyperworks are very difficult. one step doesn't lead to the correct next step. one should keep an open eye for any slight error.
thank you Prakash for following with me.
Hi sohrab I got that same error how did u resolve it can u explain me
On 2/22/2017 at 10:31 AM, Guest said:
Sohrab,
Thank you for the update.
You need to take care of the user profile. If by any chance you switch the user profile make sure you update the element type.
On 2/6/2018 at 11:03 AM, Guest said:
OK, if you still face the issue, please share the file.
Sir i am facing same error 2372 no shell properties exist in a bulk data
On 2/22/2017 at 9:16 AM, Guest said:
This is strange,
Do you mean CWELD results are shown in HV?
Can you share the .out file and .h3d file?
Sir, I facing a error ERROR 2372. No PSOLID properties exist in bulk data.  I have attached out file..
new_005.out
