Sign in to follow this
oggy
error 612/750
Help plz !!
i have these Error :
ERROR ID :          612
** ERROR IN INITIAL PENETRATION IN INTERFACE
 .. RIGID WALLS
 .. RETURNS TO DOMAIN DECOMPOSITION FOR OPTIMIZATION
 .. DOMAIN DECOMPOSITION
 .. ELEMENT GROUPS
 .. INTERFACES
ERROR ID :          750
** ERROR IN 3-NODE SHELL DEFINITION
DESCRIPTION :
   NODES DEFINING 3-NODE SHELL ID=46148 ARE ALIGNED
suggestion please !!
Hi Oggy,
Please check if there is any penetration between elements.
Goto Tools page>> Penetration>> select 2D and 3D elements to check and remove penetrations.
for error 750, check if Ish3n in /PROP/SHELL is blank or given a value. make it blank otherwise and run the analysis.
Hi Prakash,
I changed the parameters as suggested above; looks like still giving having the same Error ID 750 for my model. Can you suggest me if I need to check some other things please?
Thank you in advance.
Shawoon
Hi Shawoon,
This error is because of the tria element failing in quality. Please check and re-mesh the tria elements in the model with a higher element size and try running.
