I set up the cosimulation from the tutorial (inverted pendulum). In the end, it worked and I could adjust both, matlab and hyperworks Model for a SISO-control design.
However, I fail to set up a co-simulation with my own model. I tried to connect a Hyperworksmodel (revolution shaft cam from the motionview tutorial) with a matlab model (providing just a sine offset and one output).
By running the motionsolve model and creating an xml file for the matlab input, I receive the weird output:
Error reported by S-function 'mscosim' in 'simulinkMNModel/S-Function1': Error running MotionSolve model. Matlab Error Code: -300
Both models are attached. I don't know how to resolve this error.
Do you have any clue? Thank you.
Blumi
Hi Blumi,
thanks for sharing the files.
I am not sure if the error is from MATLAB or MS. but from the error I can make out that the error related to MATLAB. could you please check with MATLAB support on this?
Please Note: If you are a commercial customer, you can contact your local support for a script that will help you do the same @ http://www.altairhyp...ortProduct.aspx
Hey Prakash,
unfortunately, local support (Germany) does not have a Matlab license, which is why they are not really able to provide help.
We found out that the error "-300" comes from a crash by HyperWorks and is returned to Matlab.
the problem is in the Expression of the Output-SolverVariable.
DX() and AX() require Marker-IDs.
In your model there are references to Body-IDs.
Sign in to follow this
