Suraj
**ERROR ID : 760
Hello everyone,
I am new to Radioss Block120  while doing analysis I got following error :
 .. BLOCK FREE FORMAT
 .. STARTER RUNNING ON    1 THREAD
 .. CONTROL VARIABLES
 .. UNITS SYSTEM
 .. FUNCTIONS & TABLES
 .. MATERIALS
 .. NODES
 .. SKEW SYSTEMS
 .. PROPERTIES
 .. 3D SOLID ELEMENTS
 .. 3D SHELL ELEMENTS
 ** ERROR TRAPPED : REPORT TO LISTING FILE
ERROR ID :          760
please help me. thanking in advance.
Suraj
Hi Suraj,
Assign PART card image to component(s).
Right click on component(s) in model browser>> Edit>> Card Image>> PART and apply the changes.
Once done, run the job and let us know if you are through the error :)
Hiii Prakash,
Thanks for your reply. I have assigned components with Card Image>> PART.
but same error is repeating.
UBSET:         0,GLOBAL MODEL
  |________Part(s):        17,1
                           18,2
                           19,threads
                           20,b
                           22,Inner
                           23,Shank
                           25,c
                           26,Nut
                           27,washer
                           28,w1
                           29,bolt
                           30,Nut_1
 |     ABNORMAL END                                            |
 |          Segmentation Violation                             |
 |     TRACE BACK :                                            |
   GROUPS
ERROR ID :          760
** ERROR TRAPPED
Suraj
    DELETION FLAG CASE FAILURE OF MASTER ELEMENT (0:NO/1:YES) SET TO     0
      SLAVE SURFACE INPUT BY NODES
      MASTER SURFACE INPUT BY SEGMENTS
 |     ABNORMAL END                                            |
 |     TRACE BACK :                                            |
     INTERFACES
ERROR id : 760
** ERROR TRAPPED
What i should do ?
This issue seems to be with the interface defined in the model.
Please share the file through the secure dropbox link for reviewing.
Please share the starter out file. Also, please run the model checker so that we can know which interface is creating issues.
What type of analysis are you doing and what type of interfaces are there in the model.
As a workaround please remove the interface and run the model file, so that we can confirm whether this issue arise from the interface.
This is just to confirm whether this issue is causing due to the interfaces. If the deck runs fine we can confirm the same.
At that case user has to recreate the interface properly.
ESSAGE ID :          168
 ** STOP : ZERO OR NEGATIVE VOLUME
           FOR 10 NODES TETRAHEDRON ID=1747918, INTEGRATION POINT=1
     ERROR TERMINATION
 ==== End of solver screen output ====
Yes, the simulation run without any error on changing boundary condition.But my question is how it is possible that without applying contact the part is not flying, as I am fixing one component and applying force on other?And there is no transfer of force on a component other than component on which force is applied?
With the proper definition of contacts only you can a get a realistic simulation with sensible results. Since you are not defining an contacts you can check whether the components are penetrating. Only after reviewing the model we can comment much on this.
I created a example which is similar to my problem.Please suggest me solution for this.Please describe the problem solution.In my case i am using 10 noded tetra element instead of 4 noded.
Thank you
tests.rar
I just recreated the Type 2 contact in the model. When Type 2 is created select only those nodes and elements that needs to be kinematically connected.
Please go through the model file shared in the last post.
