chrisrek
Different Mesh Type
Hello
I just downloaded the academic version of the program.
I want to mesh a part with different mesh type than the already existed. For example i want to provided the locations of the nodes of the finite element,
Can hyperworks provide that possiblity?
Thank you in advance
Hello guys, i have been trying to mesh several objects for the past few days.
 Everytime, it all goes correctly, even the meshing, loads, responses, and when i assign the properties it says "elements assigned".
 Now when i run the topology, it says job terminated at "Element Quality Check - element xxxx invalid element type".
 It does this almost everytime - no matter the component.
 I try remeshing, and activated the "REMESH" from 'opticontrol', i auto clean the geometry before meshing - same outcome.
 When i try to clean mesh elements it says "unable to create hmshell.
Is there anyway i can bypass the element QI check?
I always use Volume Tetramesh - PSOLID
i can't fix all the broken elements manually.
Please advise as this has been really delaying.
Note: i have student edition so i cannot have more than 10,000 elements.
