Hallo I am having following questions
1) I am doing Modal Frequency response simulation
In  RLoad load collector  there is field called TC (see attached file) which expects input in tabular form  i have solver deck
in it the values in table is
X(1)= 0.0 Y(1)= 1.0, X(2)= 5000 , Y(2)= 1.0
what is this C ( Damping?), Is it material dependant? how is this tabular input defined
2) There is SDamping Control Card
I want to know how is the the value of g defined in TABDMP1 table in my case it is 0.02. Is it default? Again is it Material dependent?
Thanks and Regards
Pratik
post-36734-0-63033500-1427125658_thumb.j
Hi Pratik,
TABLEDi define C, In other words TC is the C in the equation.
Assuming you are apply a structural damping then you have to select CRIT as type in TABDAMPi card. Here G is 2*Critical damping.
Sign in to follow this
