I have done this ptcv joint tutorial in motionview 10 but it is not working in MV 12.I have carefully followed all instructions but it gives error saying entity b02 empty in advanced joint even though i have selected the marker and curve for body 2. Thank you for answers
HI,
Have you tried modelling the same in V 12.0?
can you share the model with us?
Thanks for sharing the file. I will look into this and get back to you ASAP!!
HI,
I am able to run the analysis at my end with 12.0 and no modifications are done for the model.
Can you share a screen shot of the error you get at your end?
In Advanced joint you have used, check if the body-2 is referring to Cam or not as shown in the picture.
some how, in your model the for Advanced joint body 2 no "body" is referred or taken,
post-7616-0-87040100-1428896287_thumb.jp
The file you shared with me is running fine at my end ( I hope this is the same file you are using).
Could you please let me know what are the updates you have?
You can find the software updates and graphics information from HyperMesh>> Help>> Updates and system information
http://forum.altairh...n-your-machine/
Sign in to follow this
