Sign in to follow this
StefanH
Size optimization to specific value
I'm trying to optimize the stiffness of a structure to a specific displacement value by changing material properties. This works fine so far but I did not figure out yet how I can set my objective that the displacement response has a specific value at the end.
Simple example:
I have a straight beam with an axial load. I want to run an optimization changing Young's modulus of the beam in order to get a nodal displacement of 2mm.
Best regards
Stefan
Your objective becomes value specific only if it is refering to Objective reference (maxmin or minmax).
but you can go ahead with your normal methodology with contraint on deplacement response as minimum =2 as well maximum = 2
In this case your obj. should be minimize mass.
I hope you are using material property as a design variable in size optimization.
I think, optistruct can't use the material properties as "parameters" or "design variables".
But I'm 100% sure that you can do that optimization with Hyperstudy, i have done it with this module.
