RAMGANESH
Error during import the model in acuconsole
Dear All,
I have been working in CFD analysis in valves
I have meshed the model using CFD tetramesh using hypermesh and exported the model as .inp file and while exporting i got the warnings in hypermesh.
while importing in acuconsole the following error occurs
kindly provide your guidelines
Thanks
Ram
post-34029-0-59963900-1432790654_thumb.p
post-34029-0-12479400-1432790660_thumb.p
post-34029-0-91948100-1432790702_thumb.p
How did you generate the volume mesh in HyperMesh? It seems that the mesh is not conform(probably at interface?)
Is it possible to upload the HM file?
Dear Sir,
I have generated the volume mesh using the steps in this tutorial       CFD-1000: Creating a Hybrid Grid using the CFD Mesh Panel in hypermesh
I got error while exporting the model to acusolve then i followed the steps in this forum http://forum.altairhyperworks.com/index.php?/topic/14825-problem-w-export-into-an-acusolve-file-inp/
by this i exported my model as .inp file.
Thanks
RAM
Generally those steps should work well. Unfortunately, it would be tough to find errors in your HM file, without looking at it. I would suggest either upload it or ask your local Altair Support team.
Let me explain my Problem.
I have two geometries (say A and B ) I created mesh individually for both of them in ICEM. Then in ICEM, I brought both meshes together and saved the .uns file.
I read it in AcuConsole and it showed me the Mesh.
While converting the Mesh to Discrete Geometry, I got the following error.
ACUSIM: There are <20218> intersections in the input mesh
ACUSIM: *** ASSERTION in Function <agsGetNumSimRegions> File <agsUtils.cpp> Line <1375>
ACUSIM: *** Simulation model is null
I have tried almost everything, but I dont quite understand why the Mesh is read correctly and why while converting to Discrete Geometry, it gives and error.
Any help on this would be very appreciated.
Juzer
It is advisable to import direct geometry (Parasolid, ACIS etc Formats) in AcuConsole if you want to mesh with AcuConsole.
If you already have a volume mesh from ICEM (or HyperMesh), why would you want to convert it discrete geometry?
TIP: If you have two geometries, one of the methods which generally works well is to import them in solidThinking Inspire and export as a Parasolid file (that can be imported/meshed in AcuConsole).
