Hi Tin,
Cool!
It works pretty well on my HyperMesh as well. Thanks a lot. I wait for this feature from Altair for many years but it sounds hopeless. I have to copy/paste folder location containing *.hm file everyday.
I believe that you can create macro to drag and drop *.key, *.fem, *.nas also soon.
Hi Tin,
Cool!
Hello Alpha
sure above macro can accept .key, .fem, .nas file
just drop them into your hypermesh
if you want to import them (instead of opening), hold down Ctr key while droping the files
Hello Alpha
Hi
I found the serious issue with this macro. After I install drag and drop macro, my hypermesh batch mesher does not work.
After I delete the macro folder, I can use Batch Mesh normally.
then, everyone should be careful when using this macro.
Thx
Hi
I fixed the problems
but i think you rarely use batch mesh because quality of HM batchmesh not so good
just neglect loading drag-n-drop mechanism when batchmesh loading pkgIndex.tcl
if {[lsearch $::auto_path */hm/scripts/batchmesh]==-1} {source [file join [file dirname [info script]] HmDnD.tbc]}
Thanks Tinh. I will test with your recommendation.
Yes. The former of HM13, mesh did not caputure geometry features well. But I am OK with mesh quality in HM13. Perhaps, my models are more simple than yours.
  How can i integrete this in to my Hypermesh.
Have a look at file "READ_ME.txt" :
//Guide
Copy folder tkdnd2.6 into ...\hm\scripts folder
No need any other setting
Internal use only
regards,
t*****@gmail.com
I have just updated it. Please download it again and
- copy folder "tkdnd2.6" to any folder you want
- open hypermesh
- enter menu File>Run>Tcl tk script and browse to the folder "tkdnd2.6" to run Installer.tcl file
- restart hypermesh
The same method can be applied to above packages "hmcp" and "tbopts"
Hello Tinh
This drag and drop script is not working in Hypermesh 2017.2 version.
I have tried installing the script using the above mentioned method.
But, it didn't work.
Can you please help it work with HM 17 also?
On 4/19/2019 at 8:18 PM, hrsq120 said:
Hello Tinh
there is a mistake on uploading the file,, you can use "tbopts " file to activate drag and drop
Really???, Installer.tcl is missing from folder tkdnd2.6, isn't it?
Yes you can copy Installer.tcl from folder tbopts to folder tkdnd2.6
It functions same except final message box title!
