Mirino
Beam: dispaly shear stress
Hi. How I would like to display the shear stresses on the beam. I have tried searching on control cards --> global output request but I haven't found anything.
Hi Mirino,
Have you defined stress recovery points on PBEAM?
you must define the stress recovery points (C D E F) in the PBEAM card to extract the results.The stress recovery point location is different for different beam/bar cross section.
Please refer to PBEAm/PBAR, PBEAML/PBARL card for more information.
post-7616-0-22793500-1433483974_thumb.jp
When you load h3d result file in HyperView, you can see a new result type like "CBAR/CBEAM Stresses (BAR)", "BAR" in the parentheses is the type name of beam cross section. That means each cross-section type has its own result group.
And you can review all the evaluation stresses (normal, shear, and von Mises) for each cross-section type, at each element end (A or B).
For instance,
Normal S3N(B) : means normal stress at the 3-th evaluation point of the beam element end B;
Shear S6S(A) : means shear stress at the 6-th evaluation point of the beam element end A;
von Mises S5V(B) : means von Mises stress at the 5-th evaluation point of the beam element end B.
And you can see maximum normal/shear/vonMises stress at the end.
I'm currently working on a solid. Is there a similar card as PBEAM for the solids in order to get the shear stress? In fact I cannot find any PBEAM or CBAR card on my hypermesh model..
Thank you,
Guerric
