jrtank
Use Temperature as Load
Can anyone help to understand how do I apply Temperature as Load instead of Heat Flux as in tutorial "OS-1090_ Linear Transient Heat Transfer Analysis of an Extended Surface Heat Transfer Fin".
On the Surface where heat flux is applied i need to apply temperature say (150°C).
Analysis > Temperatures > Create should do it.
I created as u suggested on the nodes of 1 face. But I am getting error.
Actually I am applying the temperature load in cycle and hence I am using TLOAD1 card in an load collector in which a table is used to excite the load.
The error message states "EXCITEID on TLOAD1,7 card references nonexistent DAREA,11."
Analysis > Constraints > Uncheck all the DOF’s > Load type > SPC
Now, Card edit this load collector with Config as const and type as SPC > Edit > in the filed D enter the temperature value.
I try to run thermal analysis using temperature load. I have only one component. I want to apply different temperatures on different surfaces. But I am getting error. Is it  possible to specify more than one TEMP or TEMPD load?
Hi Nihan,
TEMPD card can be used to assign a temperature for those grid/s that have not been given a temperature on a TEMP entry.
So for the same component you can pick few nodes and assign the temperature using TEMP card and for the remaining nodes assign a different temperature value using TEMPD card.
Thanks
Vikas
