Sign in to follow this
pratikhyperworks
Defining constraint
Hello Group
I wanted to know whether its is possible to define output as a constraint in optimisation.
I am validating my modell with frequency response test
I want to vary values of  Material properties like Emodulus, G modulus so that at certain frequencies Frequency Response Function FRF (velocity) is say (+\- 10 % ) of the FRF calculated by test.
eg
Vary values of
E = 1000 mpa to 2000 mpa
G= 200 mpa to 400 mpa
so that
at node 256
Frq         frf (test)     frf(simulation)
5hz          0.256         (+/- 0.01) of 0.256
10hz        0.586         (+- 0.01) of 0.586
15 hz       1.457          (+- 0.01) of 1.457 etc
Is it possible to define constraint this way
a suggestion or example tutorial would be quit helpful
Thanks and Regards
Pratik
