RAMGANESH
Slip in Boundary conditions- reg
Wall will assign zero velocity (all components) at surface.
Slip BC sets only the normal component of velocity to zero. Slip BC allows you to use coarser mesh near wall, however there would be an accuracy cost associated with that.(pressure drop results will suffer).
If slip is  assigned to mesh displacement, it allows mesh to slip along that surface.
