When running the optimization feature with Optistruct an error appears at the bottom of the screen, "Unknown beam section data type 'part_InitLengtangeLength' found in file." I'm using a beam section and bar elements to model a rod that transmits stress to the core design. No clue what this means the only issue in model checkers is "RBE3 elements are collinear" and i'm not sure if that could be the cause of the issue. It's just happens to be simultaneous issue in HyperMesh. I'm using RBE3 elements wagon wheeled on a Shell Meshed Midsurface in bore holes to simulate bolts. If anyone has some experience with these issues and could assist me it would be appreciated.
An update: I have tried running several models with and without beams. Also, have followed the Altair University instruction for modeling step by step with a provided tutorial that runs optimization with Optistruct. Still errors with a built-to-succeed tutorial. There is definitely an issue, can anyone help? It appears to be a ubiquitous error, perhaps with setup of the program or my operating system (Mac OS X 10.10.3)
"***ERROR #  61 ***
  No elements found in the input data."
pops up when using the Optistruct Solver
All the solver locates are the grid points and the program data ends there. I'm not seeing any elements, this is strange.
This issue still exists. When will it be fixed? My operating system is OS X 10.10.5 Yosemite. My Hyperworks version is 13.0, and i have installed
the latest hotfix app. Thank you.
On 6/11/2015 at 7:49 PM, Rahul Ponginan said:
 The issue is due to the operating system, HyperWorks is supported on 10.8
The issue is known to us and will be fixed in Maverick OS for eg in the future release / update.
