Sign in to follow this
jakub.ziontek
point/marker on curve
Hi Jakub,
Do you want to add a point on an existing curve?
You can actually create a curve or point using Define Curves panel in HyperGraph.
Hi Jakub,
It may not be possible to add points in extisting curve. But you can add a new curve or points.
as a work around, export the curve as a csv file and add points in the same csv file. Goto Export>>export curves to export to csv/text format.
Import the same file back in HyperGraph.
