gsre9597
Pressure import from VWT to HyperMesh
I want to apply the loads extracted from the VWT analysis to the model in HyperMesh.
As per the below procedure suggested by Altair colleague , I was able to import loads but the value of pressure was zero and in contour loads option - I get 'no results available for contour'.
I was told to do the following:
1. open vwtanalysis.acs file in AcuSolve.
2. Use AcuOut and variable 'pressure' was exported in 'table' format and 'nodal Output' type .
3. Then , using Linear interpolation option - pressure was created.
Although pressure is generated , in the HyperMesh, there is no value assigned to the pressure applied to the surface elements on the nodes on the face. (Snapshot attached)
How can I solve this issue? It would be nice , if somebody can help in sorting this problem.
Looking forward to a timely response.
Thank you.
Garima
post-37680-0-09227900-1436794322_thumb.p
Are you getting non-zero pressure values in the .OUT file generated by AcuOut?
If yes, then probably the HyperMesh forum might be more appropriate to address this issue. You will get more response :)
