cjc
Tecplot file generation
Hi all,
I am trying to extract temperature results from an Acusolve run for further simulation elsewhere, similarly to tutorial CFD-1700.
Is the Tecplot result file generated in AcuOut? I couldn't find a way to do it; Table/ Surface Output (Nodal)  gives me no variables.
Cristian
AcuOut can generate test file. I guess that suffices as Tecplot input.
If you are not getting Table/Surface Output-Nodal, you enable it by Surface > Surface Outputs > Nodal Time Frequency = 10
or another value that makes sense for your case.
