rajesh77
Dynamic analysis of a Component
I want to know the procedure for performing the dynamic analysis of a component using the optistruct.
The following are the conditions.
1.    50-500 hz frequency
2.    15g acceleration.
Can you please let me know know how to perform the analysis.
Rajesh.
Hi Rajesh,
Please refer to the below tutorials:
OS-1300: Direct Frequency Response Analysis of a Flat Plate
OS-1305: Modal Frequency Response Analysis of a Flat Plate
Please note: If you are a commercial customer, you can contact your local support http://www.altairhyp...ortProduct.aspx
Please find attached Direct Frf tutorial using Optistrcut solver.
Instead of DAREA create a unit load in a particular direction of type SPCD.
Under RLOAD refer the Spcd load collector for exciteid and the last field on RLOAD can be changed to ACCE.
Regards
Rahul R
OS_Direct _FRF.pdf
Hi Shreerang,
Both SPCD and DAREA are the load type cards used to represent a dynamic excitation.
DAREA is used to represent simple point forces / loads, which is then flagged with a table to represent time / frequency history.
SPCD is used to represent enforced / base excitations (enforcing a node/s) with Displacement, Velocity or Accelerations which are then acted upon by a table to represent time/ frequency history.
