coatkuanteen
INTERNAL PROGRAMMING ERROR in ESLM (tabscr.F)
In ESLM nonlinear-response optimization, I have a buckling constraint (LAMA) as well as a displacement constraint from IMPDYN analysis while min. mass is the design objective.
PARAM, ALTBUCK, 0 is specified. CSTRESS is not requested in IMPDYN subcase.
However, after the 1st inner loop I experience:
*** INTERNAL PROGRAMMING ERROR ***
   in file "tabscr.F", at location # 1000.
 ****  ABORTING RUN DUE TO AN INTERNAL ERROR  ****
Please see the attached files for more info.
Many thanks,
Tanut
MT_H_ESLM_2_fem.txt
MT_H_ESLM_2_out.txt
Hi Tanut,
could you please let us know what are the updates you have installed on your machine for HyperWorks?
I used the model on OptiStruct 13.0. 210 on windows machine.
I got a different error message related to convergence.
I ran it on OptiStruct 13.0. 210, windows machine but still got the same error.
Could you please try running the following .fem file again? It will take less than one hour.
https://www.dropbox.com/sh/0nqezeb8q95cbf1/AACjXJYzpkCudD8KOG0Sz2Gva?dl=0
Kind regards,
Tanut
Here are my solver versions on the Windows OS:
OptiStruct  Version 13.0.210.001
 Time of build : 23:21:01
 Date of build : Jan 12 2015
 Build tag     : 0751393_5533130_Ce64RBW8UH12M:96526
 Supported H3D : v12.0
 Radflex name  : radflex_13_win64.exe
   Use version : 130131112 or higher
RADIOSS Starter version 13.0
Platform release : win64
Platform info : Windows 64 bits, Intel compiler
Use Radflex version :  130131112 or higher
Time of build : 11:53:56
Date of build : 05/27/14
Build tag     : 0718847_1233513.000_1020_0029780_10
RADIOSS Engine version 13.0
Time of build : 11:50:02
Build tag     : 0718847_1233513.000_2020_0029780_10
RAD2RAD version 13.0
Time of build : 11:53:24
