fede_guru
Relaxing DOFs
I have a problem regarding the modelling of a ball joint. I would like to relax the three rotations of a node shared by two beam elements but couldn't find out how.
If I try to use the command 'joint' then I have to solve the simulation as a multibody dynamic problem and that looks more complicated as I need to set up more control cards like MBSIM and set up other options which I do not understand.
What's the best strategy to solve my problem?
Hi
two beams connect together with full 6 dofs
if you want to release some dofs, just update "pin flag"
enter panel 1d>bar>update to do this
and be careful that these "pin flag" dofs are in beam coordinate system, not basic system
brnlss94 likes this
On 8/8/2015 at 7:41 AM, tinh said:
Hi
Hi tinh, can I use the same procedure in radioss ??
