Sign in to follow this
vij
How to create a revolute joint using RBE2 elements
I am doing analysis of universal joint assembly (Yoke1, Spider, Yoke2). Spider is a cross member which has 4 bars extruded. So there are 4 revolute joints between trunnion and yokes.
Can anybody tell me how to create a revolute joint using RBE2 elements in Radioss Bulk Data?
https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcQsTSispqWkYwMj6cy6vS8KmDxC2gM9aMmdf_Ffk06VMnPcRNnX
To create a revolute joint between 1 bar and 1 yoke hole, I applied the following procedure:
1) Create a center node of the spider bar: node A
2) Create a center node of the yoke hole: node B
3) Create a RBE2 (Independent Node: node A, Dependent nodes: all the nodes on the portion of the bar which will be inside the yoke hole.)
4)Create a RBE2 (Independent Node: node B, Dependent nodes: all the nodes on the yoke hole.)
5) Create a local coordinate system having 'x' axis from node A to node B
6) Assign the node A and node B to local coordinate system. (set reference and set distance)
7) Create RBE2 (Independent Node: node A, Dependent nodes: node B; All dof constrained except dof4 (rotation in x axis)
Is this method correct?
Hi Vij,
What is the objective?
is it a structural analysis or a multi body simulation?
If it is a multi body simulation you can use MotionView to model the system.
