Alberto.Zapolla
Convert 2d geometry in 3d Solid
Hi i have to study the displacement on a tube. I need 3d mesh because i have to choose the material. I have as material MAT1 and as property PSOLID (i don't want PSHELL). The problem is that when i selected the surfaces with "bounding surfaces" it doesn't transform in solid because " no closed volume found".
This is one image of the tube.
What else can i do?
Thank you very much
post-41114-0-66390800-1446471024_thumb.p
In your case, the geometry is so simple. So you not need a (geometrical) solid to build your 3D mesh.
Just do a 2D mesh on a section and 3D > Drag > Drag element.
That's all.
I created the 2d mesh on the section, create 3d>drag and i obtained the model in the image. When i start the simulation i have this error
 *** ERROR # 2372 ***
 No PSHELL properties exist in the bulk data
But i take PSOLID as property. Why this happens? I don't understand
Thank you very much for your time.
Finally i did it, i forgot to delete the 2D elements. Thank you
post-41114-0-35310400-1446557620_thumb.j
