In standard baja library the rack is behind the wheel center in steering system by my assemble contains rack & steering arm ahead of wheel center(with respect to driver) so during right turn analysis car turns left side i need to rotate rack in model. How to rectify this problem?
Hi Suyash,
You can change the position of the Rack CG by changing the CG point coordinates under Rackpin Steering assembly folder.
Check if this helps to modify the model as per your geometry.
Sign in to follow this
