Giri
Ceramic Fatigue Analysis
2 hours ago, Prakash Pagadala said:
Hi Giri,
what material propertied do you have for ceramic?
What is your end objective?
ALON, aluminium nitride.
Major props:
Structure                         Cubic, Spinel
Lattice Constant              7.956–7.936 Å
Density                            3.69 g/cc
Form                               Polycrystalline
Melting Point                  2150°C
Young’s Modulus           320 GPa
Shear Modulus                135 GPa
Poisson’s Ratio               0.24
Hardness                         1800±100 kg/mm2
(Knoop indentation, 200g load)
Fracture Toughness        2.0MPa-m1/2
Flexure Strength             300-700 MPa
Specs: http://www.surmet.com/pdfs/ALON%20Data%20Sheet.pdf
Objective: Cyclic loading. HCF. Find the damage, life expectancy.
Major props:
Density                            3.69 g/cc
And Weibull model is used for reliability analysis, instead of SN curve. No idea, how can I use it in Hypermesh.
1 hour ago, Rahul R said:
If model is having shell elements you can try with Radioss XFEM to simulate crack propagation.
Regards
Rahul R
Great but I don't have any idea. Is their any documentation (tutorial) or sort?
Can't it be done in Optistruct?
Thanks.
I have attached few examples of XFEM for crack propagation.From Radioss 14.0 it will work for solid elements aswell.
In Optistruct we can do fatigue analysis using stress & strain based approach(Not sure for cermaics).Refer online tutorials for more information.
Regards
Rahul R
jpb2mstefuca_xfem3jun2014.zip
XFEM.zip
Rahul Ponginan and Giri like this
