Sign in to follow this
ANSYS TEMPLATE
Hi all,
during my parameter optimization I call Hypermesh with a command file, which sets real constants, material,..
When I execute this file manually in Hypermesh via file->command, everything works fine.
When I call this command file via MatLab/Dos, I receive error code 104. If I simplify the command file, the error doc says:
Tcl/Tk script error:
invalid command name "winfo"
while executing
"winfo exists $win"
(procedure "tableStart" line 7)
invoked from within
"tableStart display all"
(in namespace eval "::ansys" script line 1758)
invoked from within
"namespace eval ansys {
source [file join $::AnsysCompTableDir tableBase.tcl]
# next line is used to import procedures into the current na..."
(file "C:/Altair/hw8.0/hm/bin/WIN32/../../scripts/ansys/./ansysbrowser/component/tableAnsys.tcl" line 63)
Error: 13509 elements not defined in the template.
It seems to me, that there is kind of a template loading problem, which is not present when you are in Hypermesh, but which struggles when you call hypermesh via DOS.
Anyone encountered this problem before?
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
