duanetran
Optistruct Analysis with SET ID
I am running a direct transient analysis of a model.  i have created the set with two nodes.  global output cards show displacement, velocity, and acceleration.  The analysis gives me a _tran.mvw file which is correct.  however, the default graph that opens up is the displacement graph of one node.  how do i switch the graph from displacement to acceleration, as well as switch to the graph that shows the other node?
