Sign in to follow this
new differential
And that little bit more help with entering into the seabed:
Dawson Double Acting Hydraulic Impact Hammers
Posted Image
Regards Andrew o:)
Well, who would have thought that Newcomen was so close to an adequate solution #-o
Posted Image
Posted Image
Regards Andrew =d>
Beautiful simple new 4 stroke kinematics animation made at the
King Soud University.
Posted Image
And a little faster
Posted Image
Regards Andrew#-o
I also very close to the Technology
Posted Image
Regards Andrew #-o
I think that this technology is very effective. Can you imagine that by doing the same movement up and down through the traditional piston-connecting rod-crankshaft to get the same ease the movement of this vehicle?
I think that it would then be much harder work. And these four , the looks on it, they not liked to work more than need....
Regards Andrew
However and that will had such a good humor, just take a timber and a little grease lubricated. #-o
Do not need any oil !! #-o #-o
Seal or Teflon or lubricated with diesel fuel.
OIl = diesel fuel in this picture
Posted Image
Regards Andrew=d>
Some new4stroke history:
Print table of Fortran 1982 program.
I could choose from 100 of these tables, each for different angular positions of crakshafts.
Here is one of them:
Posted Image
Working drawing of the head:
Posted Image
Regards Andrew #-o
The first windmills pumped water in America. To sustain this good tradition, I developed a little more modern sytem for the production of electric current in a similar way of pumping water.Whether American landscape views, are water sphere.I decided to add this view to the next shot where the water will be collected water so that it could give electrical energy when draining it back into the lower reservoir.
Posted Image
This water will be pumped sphery as in the first versions of windmills, wind.
The wind turbine will move a small diameter, but it is a multi-blade, placed together with the hydraulic pump in the middle of a specially constructed balloon. Balloon will be tethered, as previously barrage balloons.
Only that will go along the line, hydraulic pipes, the hydraulic motor, which will be driven water pump located in the lower reservoir.The water pump will continuously pump water to sphery. Now the water falling from the lower reservoir back to the shery, will do an electric current through hydrogenerator.
Posted Image
Posted Image
Every so water sphere about the capacity of 2000 m 3, and the height 100 m can give power 10 MW for 3 minutes. If filling pumps water with the one I believe loss is managing to fill waters up, we will have it 10 MW driven with wind turbine in balloons.
Of course, the balloons could be filled up by hydrogen, because today we have very good material on the shell.
This system could be installed in any place where electricity is needed, and thus would have limited losses on the transfer.
Also low noise, and the invisibility of the rotating blades, not to interfere in coexistence with the environment.Balloons can be affixed to a height of 150 to 200 meters, where the wind is always blowing on the ground even when there is absolute silence.
some links:
http://media.primezone.com/cache/189/int/8385.jpg
http://www.engadget.com/2010/06/21/northrop-grumman-wins-contract-to-build-us-armys-long-endurance/
Regards Andrew :smokin::smokin:
On Saturday is the anniversary of 9 / 11, and make this possible, I decided to share with my good deed ,publication of this study.
Posted Image
http://www.911dayofservice.org
Posted Image
Of course, two rotate in one direction and two in the opposite direction.
You must use a very light hydraulic oil. If it were not frozen in winter.
Hydraulic pump in the balloon has the best power to weight ratio. All the airlines are working on the hydraulic actuators.
Of course, all of the balloon must be tested in the wind tunnel aerodynamic, in order to fully match the efficiency of the 21st century.
Some pictures of how to create a balloon from the inside :rolleyes:
Posted Image
Posted Image
and NASCAR wind tunnel
Posted Image
Regards Andrew #-o
There is a way to shorten a bit of flexible hydraulic tube...
Posted Image
Well, if it accidentally escaped gas from the balloon and so it can be:-"
Posted Image
Name : Jazz Big Band
Posted Image
Regards Andrew :-k
To those dixielnds can efficiently drive Hydraulic, it may have, no peaks of specialized software, use the links below.
http://www.hippocampus.org/homework-help/Physics-B/Fluid%20Mechanics_Venturi%20Tube%20-%20Simulation.html
http://www.ce.utexas.edu/prof/kinnas/319lab/applets/venturi/venturi.html
http://www.globalsecurity.org/military/library/policy/army/accp/al0966/le2.htm
The lower pressure propeller spins quickly ....
And review of the fact that it's not worth double the turbine insert...
Regards Andrew :-" :-"
A new way of sailing through a balloon which has the wind, and transmits energy to the propeller using hydraulics
Posted Image
And sailing version of the Venturi jets
Posted Image
I simply will look as flat block. It can be cast as a single unit. It did not need the division on the block and head. Because the pistons can be put at the bottom......
It is full 4 stroke engine.
Posted Image
Posted Image
Posted Image
Regards Andrew#-o
But perhaps the experience of the Ice Race can to help you change the aerodynamics in F1?
But in F1, there are winds above 300 km / h !
Fighter aircraft F-104 starts at a similar velocity. Right then, about 700 KG per 1 square meter load.
If using a well-sculpted are did the 700 KG used to accelerate boild F1 ......
I think that not everything has been said in the aerodynamics of F1.....
700 KG at 1 m^2 - 70 KG forward at 10 dcm^2 aditional F1 wings....
Regards Andrew:-" :-"
Posted Image
Regards Andrew :-k
This problem ereting towers
can be resolved with Jazz Big Band. Just half of the turbine rotates in one direction and half in another page.
I did this study in the Venturi nozzle turbine and the calculations have a rather surprising results. Back to front.;)
Posted Image
Well, energy is the same at the entrance, like a normal windmill. Only I noticed that the amount of energy produced by the windmill, the third power (cube)depends on the speed of the wind.
Windmill depends on the diameter of the second power (sqare).
So I started with a lot of it is better to improve the efficiency of wind turbine using wind speed increases, and not via increasing the diameter of the fan.
Serves to increase the velocity venturi nozzle
V^3 , D ^2
As curiosity I enter the number of Hp has the arrangement of 15 m / sec. = 270 Hp
You probably use a turbine engine derived from a helicopter, to generate such energy
Regards Andrew:-" :-" :-"
