Sign in to follow this
new differential
Holidays are approaching, so we do spring cleaning. For sure we will use the vacuum cleaner. We can using such a vacuum cleaner to see how the underground windmill will run . Namely, you should close the pipe vacum cleaner is best without the caps to a small fan, for example, to cool the CPU, or a computer power supply. We will have a working model of an underground windmill......
The following picture shows the sports exhaust, which are built with a relatively long individual pipes from each cylinder. Their length L is crucial for their proper operation. Mass departing exhaust with a volume of such tubes will help the new portion of air intake into the cylinder, while the common valve opening. This mass is precisely calculated for the speed at which it will perform a so-called dynamic charge of the engine
Posted Image
Just the energy contained in the exhaust of precision of the volume of the exhaust manifold vacuum in the cylinder does.
Happy Easter !
Andrew #-o
Posted Image
This is Homer. Now you can safely drink, because he knows the underground fan will give him a lot cheaper green energy.
It can use an underground windmill used an old engine, for example, the Harrier. Or the same fan.
Posted Image
Regards Andrew:-" :-"
"The gain in kinetic energy resulting from the increased linear velocity in the throat is offset (i.e., balanced) by the decrease of pressure in the throat. The reduction in pressure which occurs when the fluid flows through the throat is called the Venturi effect and is named after the Italian physicist Giovanni Battista Venturi (1746 - 1822) who first observed the effect."
http://en.citizendium.org/wiki/Venturi_effect
http://www.hippocampus.org/homework-help/P...Simulation.html
Andrew:-" :-"
Lesson Two: in terms of fundamental historical
Venturitubes 1937.pdf
On the pictures below you can see how small the venturi nozzle is to drive the gyroscopes in the strands. My finger and applied on the next hand, illustrate the size of the venturi tube. It is almost equal to the diameter of my finger. Now, please imagine how much energy to give the fan with the same diameter of my finger...
Posted Image
Posted Image
Since the narrowest point of the venturi tube, we can easily get up to 10 times higher air velocity, we can mount the engine behind the jet frame, which at high speeds the inlet has a good performance.
For example, you can mount an engine on an Tourist Plane, which reaches 200 km / h at the entrance to the RAM JET would be about 2000 km / h....
This will generate additional good sequence, using a very simple engine ( or two )
Posted Image
Regards Andrew
Regards Andrew
A venturi tube so small as my finger is able to propel a large heavy rotating disk gyroscope air to 10 000 RPM, and even walk through the air filter....
Posted Image
Since the gyroscope can be power, relatively high compared to the diameter of the venturi tubes (1 ") and he has the 2 ", then maybe you can do in F1 KERS Venturi "?
The air sucked into the engine can be sucked through a venturi tube so, resulting in a negative pressure to drive the gyroscope, which will keep energy....:tsk
That would be something like a turbine gives energy, but the intake pipe. Turbo :D
Posted Image
Regards Andrew
Originally posted by monkeysandbearspants
Having digested the content of the thread i conclude that the answer could be one of these !!
However weight may be an issue and mostly certainly there would need to to be some boot modifications!
Posted Image
http://www.full-ahead.net/Silownia/silniki_pomocnicze/sp_index_ang.htm
http://www.full-ahead.net/Silownia/silniki_pomocnicze/remont_sp/awarie_remont/glowica_urw_zaw_isadora/glow_urw_zawor.htm
http://www.full-ahead.net/Silownia/silniki_glowne/sg_index_ang.htm
double bottom fo foam
http://www.youtube.com/user/pawielus?gl=PL&hl=pl#p/u/53/Cfp0BWKwdgY dno
large swimmer:
http://www.youtube.com/user/pawielus?gl=PL&hl=pl#p/u/92/mnxWu3oWghs
Regards Andrew :D
The Red Baron Windmill:
Due to the vacuum created by the wing, over which the wind flows, wind turbines in the channels of collective spin vacuum and provide energy....
Posted Image
Here you can see demonstrations of the film that created a vacuum at the top of the wing when the wind blows on him.
The resulting vacuum can suck the ball into the pipe passing through the wing.
http://youtu.be/Fb8IFfnbjY8
By placing many of the holes on the top of the wing, use the vacuum on the entire surface of the wing. The Assembly shall meet in two sustaining supports and drives the suction fans to them with normal air pressure.
This will of course be used to produce energy,
and its amount will depend on the size of the system...
Well, some developing:
Of course, you must use the entire art of loving wing aerodynamics.
And How companies grow one way: speed amplifier in the form of air intake venturi nozzle.
Posted Image
Well, and a new kind of wings...
Venturi nozzle flat... After all the two wings made contrary to each other..
Posted Image
In other forum :
Those wings need endplates.
Seriously - using the flow in a secondary device means that a lot of the wind power is wasted, because the mass flow through the turbines is much less than the wind mass flow captured by the machine.
I have seen some interesting and original ideas in this thread, but you are wasting YOUR energy trying to improve on the efficiency of a modern wind turbine.
All of this, I waste my energy ,you able to understand that there are other, much more efficient ways of using wind energy.
I know your great love for modern wind turbine, but you must remember that any excessive love sent your eyes, and impossible for an objective view of reality.
Besides, is not just about the same efficiency, but also for it to be able to build a very simple structure that even the next 4,000 years will exist. I makes sense to build on the sea, because they almost always wind blows from one direction - from the sea. And so it will probably still over the next 4000 years...
  In such a structure may be, for example, 100 such horizontal " flat venturi " and long for 300 meters. Constructed channels will lead to negative pressure turbines which generate much electricity. And the only element consuming to be turbine generators. The rest should survive 4000 years without repairs...
So with these issues will be decisive, not only we can improve the efficiency of Venturi amplifier.
Well unless the people have lost the ability to build such structures ...
Posted Image
And here in a better resolution though you wanted to see more details:
http://upload.wikimedia.org/wikipedia/commons/a/af/All_Gizah_Pyramids.jpg
But who will be Pharaoh??
Regards Andrew :-" :-"
And here's the picture of Homer family watching the Red Baron Windmill prototype with flat Venturi nozzles.
If you meet all expectations, this is a prototype of Homer performs with Stone, as Pharaoh himself had wished.
And it will be a very durable building, well, for example, compared to the ridiculously short life of nuclear reactors...
Posted Image
Best Regards Andrew:-" :-"
With a dash of fantasy.
Oh yes, a little bit of you have, then a little knowledge and work reliably over the idea and new invention ready.....
Here you can see perfectly that we can get plenty of potential energy generated by the aerodynamics, without any propellers....
It allows a range of up to 3000 km by glider...
http://en.wikipedia.org/wiki/Gliding
Andrew:-" :-"
In other forum:
Andrew:stir:
The main energies supplied to a glider is gravity and convection(solar) energy. Even a glider has to be able to change it's vector to operate at a gain. At the end of the day, a glider has produced very little work. If you were to try to power the world on the work performed levels of a glider, it would be a herculean task.
Instead, we can build an automatic flow of balls so that they can be sucked into the pipe.
A falling ball (or WATER) with wings, they can hit their way back after a shoulder wheel, similar to a water wheel, giving him his potential energy ..
Well, the automatic circuit, will cause the "Hercules" he can rest.
This is just an example of how we can use another way of generating energy this way.
"The Water Wind Power Plant"
Love for "tuning" not gone...
Posted Image
Andrew:-" :-"
I actually wasted 2 min typing that text in google translator and came up with this:
"scientists believe the surface of his wings is too small in relation to its weight and in accordance with the laws of physics can not fly ... But the bumblebee does not know ..."
K.Lagan
Andrew:-" :-"
In other forum:
Correct if you calulate based on single lift pulse per wing cycle. Bees get 2 lifts per wing cycle. People used to think the earth was flat and at the the center too.
Please to let us know how to make complex structures that are both strong enough to self suport and to resist 4000 years of storms? We simple people can see how a simple shape pile of rocks could last in an area that does not see sub 0C temps. Now all you need to do is figure out how to make electricity from a pile of rocks.
The pile of rocks:
Posted Image
Hmmm, as someone with a structural engineering background, I see potential problems with that structure :lol:
Needs more rocks.
No, I think it needs less air.
And I have hope that over the last 4,000 years we have learned, to build something more than just the pyramids and the pyramids.... :roll:
Andrew:-" :-"
Well, with that lovely airfoil texture, I'm sure that that will start producing usable amounts of energy any time it's within the eyewall of a hurricane....
Also such a pile of stones, and a dangerous element of water, politely puts 2000 MW....
Posted Image
Andrew:-" :-"
Not stones, Concrete with much steel and piping in it. Well under 100 years old and under constant care, maintenance and upgrades. Nothing polite about this project. Read up a bit and you will find it was made out of men and material. 0.0 % clever, 100% brute force and slide rule engineering.
Concrete is a pile of stones, only a tiny...
If we use the design of computers, calculators to calculate the type,
http://www.flowmeterdirectory.com/flowmeter_venturi_calc.html
http://www.hanleyinnovations.com/vf50.html
It can be 100% clean design
And even more politely 'll gain energy. And then it will be possible, for the next 4000 years.
Andrew:-" :-"
