nextdc
Export iso-surface mesh
Hi
I've been experimenting with the radiation hazard zone example (Example-D04-Radiation_hazard_zones). My question is, how can I export the INIRC88_E_80percent iso-surface as mesh for use elsewhere? Is there a method to do this via a script?
thanks
David
Hello David,
This is not possible with the current version that is available to users, but this feature will become available with the next feature update to FEKO 14.0, nl. 14.0.410. We expect it to be released in a few weeks (2 to 3 weeks). Once you have access to FEKO 14.0.410, you can use the new ExportIsoSurfaceToSTL(filename) method on the NearField3DPlot object in the API to perform the export. This feature will not be available in the GUI.
I hope that helps and that you can wait a few weeks for the feature.
Regards
JIF
