CrisWu
Format of OS files
According to the FEKO user manual, the os file ( surface current density) format is  following:
Num X Y Z Re(Jx) Im(Jx) Re(Jy) Im(Jy) Re(Jz) Im(Jz) ...
... Abs(Jcorn1) Abs(Jcorn2) Abs(Jcorn3) ...
... Re(Jx_c1) Im(Jx_c1) Re(Jy_c1) Im(Jy_c1) Re(Jz_c1) Im(Jz_c1) ...
... Re(Jx_c2) Im(Jx_c2) Re(Jy_c2) Im(Jy_c2) Re(Jz_c2) Im(Jz_c2) ...
... Re(Jx_c3) Im(Jx_c3) Re(Jy_c3) Im(Jy_c3) Re(Jz_c3) Im(Jz_c3)
My question is  what does  c1,c2,c3 means ?  The current at three corners of triangles?  The X Y Z value seems to be the center of triangle( i checked with mesh file) .
if they corners of triangles , how to determine their coordinates. Does any one have a clue ?
Thanks.
Cris
Dear Cris
Yes, c1, c2 and c3 refers to corner1, corner2 and corner3.
The locations of the corners can be written to the FEKO *.out file using the "Export to the FEKO *.out file" option for Geometry under the General tab of the Solver settings in CADFEKO.
Your FEKO *.out file should then contain a section such as below:
                         DATA OF THE METALLIC TRIANGLES
 no.       label     x1 in m     y1 in m     z1 in m       edges
          medium     x2 in m     y2 in m     z2 in m
          medium     x3 in m     y3 in m     z3 in m
                       nx          ny          nz          area in m*m
        1 Cuboid   1.0000E+00  0.0000E+00  1.0000E+00            1         2         3
          Free s   9.2172E-01  7.3931E-02  1.0000E+00
          Free s   9.1669E-01  0.0000E+00  1.0000E+00
                   0.0000E+00  0.0000E+00  1.0000E+00      3.0797E-03
        2 Cuboid   1.0000E+00  8.3374E-02  1.0000E+00           -1         4         5
          Free s   1.0000E+00  0.0000E+00  1.0000E+00
In the above corner1 is given by (x1,y1,z1), corner2 by (x2,y2,z2) etc.
On 2016/3/13 at 11:45 AM, Johan Huysamen said:
Dear John,
Thanks. By looking at the out file, i can find the corrdinates for each corner of a triangle,  However, something is strange when it comes to the OS file.
As you can see from the out file, the second corner of trinagle 1 is also the second corner of triangle 2, but in the OS file , the electric current density at corner 2  of triangle1 and 2 are different. This doesn't make sense to me, they are at the same position, so their current density should be the same.
        1 Union1   0.0000E+00  1.3900E-01  0.0000E+00            1         2
                    0   1.9586E-03  1.3710E-01  0.0000E+00
                    0   2.8494E-03  1.3900E-01  0.0000E+00
                         0.0000E+00  0.0000E+00  1.0000E+00      2.7097E-06
        2 Union1   0.0000E+00  1.3601E-01  0.0000E+00           -1         3
                    0   0.0000E+00  1.3900E-01  0.0000E+00
                         0.0000E+00  0.0000E+00  1.0000E+00      2.9245E-06
        3 Union1   2.5267E-02  1.3900E-01  0.0000E+00            4
#Characteristic Mode Index: 1
#No. of Header Lines: 1
#                 "Num"             "X"               "Y"               "Z"               "Re(Jx)"          "Im(Jx)"          "Re(Jy)"          "Im(Jy)"          "Re(Jz)"          "Im(Jz)"          "Abs(Jcorn1)"     "Abs(Jcorn2)"     "Abs(Jcorn3)"     "Re(Jx_c1)"       "Im(Jx_c1)"       "Re(Jy_c1)"       "Im(Jy_c1)"       "Re(Jz_c1)"       "Im(Jz_c1)"       "Re(Jx_c2)"       "Im(Jx_c2)"       "Re(Jy_c2)"       "Im(Jy_c2)"       "Re(Jz_c2)"       "Im(Jz_c2)"       "Re(Jx_c3)"       "Im(Jx_c3)"       "Re(Jy_c3)"       "Im(Jy_c3)"       "Re(Jz_c3)"       "Im(Jz_c3)"
                  1                 1.60267301E-03    1.38366026E-01    0.00000000E+00    -6.00105204E-01   0.00000000E+00    -1.46378183E-01   0.00000000E+00    0.00000000E+00    0.00000000E+00    9.70146150E-01    6.79031533E-01    3.12246041E-01    -9.70146150E-01   0.00000000E+00    0.00000000E+00    0.00000000E+00    0.00000000E+00    0.00000000E+00    -5.17923422E-01   0.00000000E+00    -4.39134548E-01   0.00000000E+00    0.00000000E+00    0.00000000E+00    -3.12246041E-01   0.00000000E+00    0.00000000E+00    0.00000000E+00    0.00000000E+00    0.00000000E+00
                  2                 6.52869335E-04    1.37370583E-01    0.00000000E+00    1.47271182E-01    0.00000000E+00    -1.30962443E+00   0.00000000E+00    0.00000000E+00    0.00000000E+00    1.61571009E+00    1.44052091E+00    9.42068288E-01    0.00000000E+00    0.00000000E+00    -1.61571009E+00   0.00000000E+00    0.00000000E+00    0.00000000E+00    4.41813547E-01    0.00000000E+00    -1.37109492E+00   0.00000000E+00    0.00000000E+00    0.00000000E+00    0.00000000E+00    0.00000000E+00    -9.42068288E-01   0.00000000E+00    0.00000000E+00    0.00000000E+00
rect shape.cfx
